Salta al contenuto principale
Linksys EA9200 Power Switch Replacement
Cosa ti serve
  1. Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: passo 1, immagine 1 di 2 Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: passo 1, immagine 2 di 2
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 Power Switch Replacement: passo 2, immagine 1 di 2 Linksys EA9200 Power Switch Replacement: passo 2, immagine 2 di 2
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 Power Switch Replacement: passo 3, immagine 1 di 3 Linksys EA9200 Power Switch Replacement: passo 3, immagine 2 di 3 Linksys EA9200 Power Switch Replacement: passo 3, immagine 3 di 3
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 Power Switch Replacement: passo 4, immagine 1 di 3 Linksys EA9200 Power Switch Replacement: passo 4, immagine 2 di 3 Linksys EA9200 Power Switch Replacement: passo 4, immagine 3 di 3
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 Power Switch Replacement: passo 5, immagine 1 di 3 Linksys EA9200 Power Switch Replacement: passo 5, immagine 2 di 3 Linksys EA9200 Power Switch Replacement: passo 5, immagine 3 di 3
    • Lift the board and pull down, away from the antennas.
  6. Linksys EA9200 Power Switch Replacement, Power Switch: passo 6, immagine 1 di 3 Linksys EA9200 Power Switch Replacement, Power Switch: passo 6, immagine 2 di 3 Linksys EA9200 Power Switch Replacement, Power Switch: passo 6, immagine 3 di 3
    • Desolder the 7 pins for the power switch from the backside of the circuit board.
    • In order to remove this part you will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
    • Come saldare e dissaldare componenti elettrici is iFixit's official guide on how to use a soldering iron.
Conclusione
Shane Davis
Membro da: 10/05/16
374 Reputazione
3 Guide realizzate
USF Tampa, Team 9-1, Lacy Fall 2016 Membro di USF Tampa, Team 9-1, Lacy Fall 2016
USFT-LACY-F16S9G1
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 507
