Salta al contenuto principale
Lenovo Z70-80 Keyboard Replacement
Cosa ti serve
  1. Lenovo Z70-80 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Lenovo Z70-80 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Use your fingers two push both latches away from each other to release the battery.
    • Pull the battery out.
  2. Lenovo Z70-80 Keyboard Replacement, Keyboard: passo 2, immagine 1 di 3 Lenovo Z70-80 Keyboard Replacement, Keyboard: passo 2, immagine 2 di 3 Lenovo Z70-80 Keyboard Replacement, Keyboard: passo 2, immagine 3 di 3
    • Carefully pry up the keyboard with the flat end of a spudger and remove all of the 3mm Phillips #0 screws.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the keyboard cable out of the socket.
    • Remove the keyboard.
Conclusione
Gateway, Team S1-G4, Johnson Spring 2018 Membro di Gateway, Team S1-G4, Johnson Spring 2018
GCC-JOHNSON-S18S1G4
2 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,563
