Salta al contenuto principale
Lenovo Yoga C930-13IKB Touch Pad Replacement
Cosa ti serve
  1. Lenovo Yoga C930-13IKB Touch Pad Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 2, immagine 1 di 2 Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 2, immagine 2 di 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 3, immagine 1 di 2 Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 3, immagine 2 di 2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: passo 4, immagine 1 di 3 Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: passo 4, immagine 2 di 3 Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: passo 4, immagine 3 di 3
    • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
    • Use the spudger for assistance.
  5. Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 5, immagine 1 di 1
    • Unscrew the four 3mm screws with a Phillips screwdriver.
  6. Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 6, immagine 1 di 2 Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 6, immagine 2 di 2
    • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
    • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
    • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
    • Repeat the procedure for the second strip on the opposite side of the battery.
    • Be careful not to bend the battery. Breaking the battery is dangerous.
    • Remove the battery with your hands.
  7. Lenovo Yoga C930-13IKB Touch Pad Replacement, Touch Pad: passo 7, immagine 1 di 2 Lenovo Yoga C930-13IKB Touch Pad Replacement, Touch Pad: passo 7, immagine 2 di 2
    • Unscrew the four 2 mm screws with a Phillips #00 screwdriver.
  8. Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 8, immagine 1 di 3 Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 8, immagine 2 di 3 Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 8, immagine 3 di 3
    • Carefully pull out the small electrical wire from the back of the touch pad.
  9. Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 9, immagine 1 di 2 Lenovo Yoga C930-13IKB Touch Pad Replacement: passo 9, immagine 2 di 2
    • The touch pad must be slid out before being lifted out.
    • Lift up the touch pad.
    • Slide the touch pad out of the laptop.
Conclusione
Matteo
Membro da: 01/23/20
97 Reputazione
1 Guida realizzata
Cal Poly, Team S19-G5, White Winter 2020 Membro di Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 822
