Introduzione
Lenovo Yoga Book X90F. Model number: Lenovo YB-J912F. This guide will help to replace the keyboard if it does not work after trying to turn it on. This keyboard is useful when using the Lenovo Yoga Book in laptop mode. The relevant troubleshooting section can be found using this link. Please be aware that when replacing the screen, there is a large possibility that it will crack and will need to be replaced. Take caution as the screen is made of glass.
Cosa ti serve
Turn off and power down the device before beginning this process. A heat gun or hair dryer will be suitable to heat the adhesive that holds down the screen. Apply heat to the entire surface area of the bottom screen.
3 Commenti
Was your keyboard cracked before you removed it? I see the first photo has an intact keyboard...
I've been given two of these, one with a dead keyboard and the other with a destroyed primary display. I want to transfer the functioning keyboard to the other intact machine. Is that possible, or will that destroy the keyboard?
Hi Sam, it looks like no one has replied - my answer would be that the keyboard will be destroyed. I had to remove the keyboard to replace the battery, and the guide on IFixit for that implied that the risk of removing the keyboard meant destroying it. So I accepted that risk, and now I am trying to source the [right] replacement keyboard. I was sent a Spanish language keyboard, which really isn't right for me and have said that to the seller and asked for the English version, but sadly they were out of stock. If you have found one please let me know!
An addendum to my previous comment, this Youtube video suggests you might get away with it Sam! Probably requires the right heatgun (maybe not a hairdryer!) And patience...
