Salta al contenuto principale
Lenovo Yoga 900-13ISK Trackpad Replacement
Cosa ti serve
  1. Lenovo Yoga 900-13ISK Trackpad Replacement, Back Cover: passo 1, immagine 1 di 2 Lenovo Yoga 900-13ISK Trackpad Replacement, Back Cover: passo 1, immagine 2 di 2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Trackpad Replacement: passo 2, immagine 1 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement: passo 2, immagine 2 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement: passo 2, immagine 3 di 3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Trackpad Replacement, Battery: passo 3, immagine 1 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement, Battery: passo 3, immagine 2 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement, Battery: passo 3, immagine 3 di 3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Trackpad Replacement: passo 4, immagine 1 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement: passo 4, immagine 2 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement: passo 4, immagine 3 di 3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Trackpad Replacement, Trackpad: passo 5, immagine 1 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement, Trackpad: passo 5, immagine 2 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement, Trackpad: passo 5, immagine 3 di 3
    • Use a spudger to lift the hinged black tab of the ZIF connector on the trackpad.
  6. Lenovo Yoga 900-13ISK Trackpad Replacement: passo 6, immagine 1 di 2 Lenovo Yoga 900-13ISK Trackpad Replacement: passo 6, immagine 2 di 2
    • Pull the cable out from the connector with your fingers.
  7. Lenovo Yoga 900-13ISK Trackpad Replacement: passo 7, immagine 1 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement: passo 7, immagine 2 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement: passo 7, immagine 3 di 3
    • Remove the six 2.2 mm screws from the trackpad with a Phillips #00 screwdriver.
  8. Lenovo Yoga 900-13ISK Trackpad Replacement: passo 8, immagine 1 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement: passo 8, immagine 2 di 3 Lenovo Yoga 900-13ISK Trackpad Replacement: passo 8, immagine 3 di 3
    • Press the trackpad up from the bottom by opening the laptop slightly and applying pressure from the keyboard side.
    • Remove the trackpad.
Conclusione
Austin Blakely
Membro da: 03/11/19
19.631 Reputazione
53 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.298 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 321
