Introduzione
This step-by-step repair guide will show you how to replace the keyboard in the 13 inch Lenovo Yoga 900. Whether you have a malfunctioning key or the whole keyboard has ceased to work, replacing your keyboard will get you back to typing. Fortunately, the keyboard in the Yoga 900-13ISK is modular, so you can replace it without needing to replace the entire palm rest.
Be sure to unplug and completely turn off your device before you start working.
Cosa ti serve
Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
Use a Phillips #00 screwdriver to remove the 2.7 mm screw that is holding down the SSD card.
Pry up the gray and black coaxial cables from the Wi-Fi card using a spudger.
Move the cables to the side.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using the pointed end of a spudger, flip up the hinged locking tabs of the eight ZIF connectors on the motherboard.
Pull the eight cables out from their connectors using a pair of blunt nose tweezers.
Use a spudger to pry up the press fit connector on the right side of the motherboard.
Remove the two 3.5 mm screws from the charging port with a Phillips #00 screwdriver.
Remove the 3.6 mm screw from the daughterboard on the right with a Phillips #00 screwdriver.
Altre 3 persone hanno completato questa guida.
