Salta al contenuto principale
Lenovo Yoga 710-14IKB Battery Replacement
Cosa ti serve
  1. Lenovo Yoga 710-14IKB Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Battery Replacement: passo 2, immagine 1 di 3 Lenovo Yoga 710-14IKB Battery Replacement: passo 2, immagine 2 di 3 Lenovo Yoga 710-14IKB Battery Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Battery Replacement, Battery: passo 3, immagine 1 di 2 Lenovo Yoga 710-14IKB Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Battery Replacement: passo 4, immagine 1 di 2 Lenovo Yoga 710-14IKB Battery Replacement: passo 4, immagine 2 di 2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery.
Conclusione
Altre 20 persone hanno completato questa guida.
Grant Doerksen
Membro da: 04/17/17
1.005 Reputazione
5 Guide realizzate
Cal Poly, Team S14-G5, Banghart Spring 2017 Membro di Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
4 Membri
21 Guide realizzate
7 Commenti
Thank you for posting this battery replacement guide! I’m not huge on computer tech stuff and because of the holidays a lot of repair shops were closed. So, I found this, the tools I needed and bought a battery off ebay and I did it myself. I saved so much time and money(i’m sure) because of these simple instructions. Although I have the 710-15IKB, everything was basically identical. Thank you !
envykiss99 - Replica
Thank you making this guide for a battery replacement!
I replaced the battery, but now the computer won’t turn on! what am I doing wrong?
chrismark1 - Replica
I you haven’t yet, try plugging the laptop into power to see if it runs off of AC power.
Arthur Shi -
Worked great. thx
John Smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 121
Tutti i Tempi: 19,353
