Salta al contenuto principale
Lenovo V14-IIL Fan Replacement
Cosa ti serve
  1. Lenovo V14-IIL Fan Replacement, Back Panel: passo 1, immagine 1 di 2 Lenovo V14-IIL Fan Replacement, Back Panel: passo 1, immagine 2 di 2
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Fan Replacement: passo 2, immagine 1 di 1
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Fan Replacement: passo 3, immagine 1 di 1
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Fan Replacement, Fan: passo 4, immagine 1 di 2 Lenovo V14-IIL Fan Replacement, Fan: passo 4, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the three 6 mm screws holding the fan.
  5. Lenovo V14-IIL Fan Replacement: passo 5, immagine 1 di 3 Lenovo V14-IIL Fan Replacement: passo 5, immagine 2 di 3 Lenovo V14-IIL Fan Replacement: passo 5, immagine 3 di 3
    • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
    • Remove the LAN cables from the three brackets on the fan.
  6. Lenovo V14-IIL Fan Replacement: passo 6, immagine 1 di 1
    • Lift out the fan gently pulling until the four cables disconnect from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 147
