Introduzione
The random access memory (RAM) module is an essential component to a functioning and working laptop. The RAM is a component that stores short-term memory and is completely different from other memory modules or storage devices in a laptop, such as a SSD or a hard drive. Some boot-up procedures and programs may be stored on the RAM when a device is turned on.
If you find that your device is slower than usual or if it isn’t properly booting, it may be time to replace the RAM. Follow these instructions to replace the RAM in your Lenovo ThinkPad T450.
Cosa ti serve
Using your hands, slide the two locking tabs away from each other to release the battery.
Slide the battery up and out of the device.
Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
Lift up the black piece of tape and remove it to uncover the RAM sticks underneath.
Altre 2 persone hanno completato questa guida.
