Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will show the removal / replacement process for the webcam above the LCD if damaged.
Guide Notes
  • You should only follow this guide after ruling out software issues from the list of problems and performing an exhaustive troubleshooting. Only replace your webcam if you are sure that the component is physically damaged. If your webcam stopped working after a liquid spillage or after crushing the webcam area, you may have to replace it.
  • Please look up and try troubleshooting solutions to common webcam software problems, such as missing or outdated drivers, disabled webcam, etc.
  • The webcam can be removed without first removing the LCD screen, although the screen is removed in this guide's pictures.
  1. Use a spudger to remove the plastic covers from the LCD screen. Use a spudger to remove the plastic covers from the LCD screen.
    • Use a spudger to remove the plastic covers from the LCD screen.
  2. Remove the two 6.0mm screws on each side using Philips #0 head screwdriver as shown in the picture.
    • Remove the two 6.0mm screws on each side using Philips #0 head screwdriver as shown in the picture.
  3. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  4. Use a spudger to separate the bezel of the LCD screen.
    • Use a spudger to separate the bezel of the LCD screen.
  5. Continue along the edges lifting up and prying off the plastic LCD bezel. Continue along the edges lifting up and prying off the plastic LCD bezel. Continue along the edges lifting up and prying off the plastic LCD bezel.
    • Continue along the edges lifting up and prying off the plastic LCD bezel.
  6. Remove two 3.5mm Phillips #0 screws.
    • Remove two 3.5mm Phillips #0 screws.
  7. Carefully detach the connector from webcam assembly.
    • Carefully detach the connector from webcam assembly.
    • Remove the webcam from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Harsh Patel
Membro da: 02/10/2017
287 Reputazione
2 Guide realizzate
USF Tampa, Team S1-G2, Thompson Fall 2017 Membro di USF Tampa, Team S1-G2, Thompson Fall 2017
USFT-THOMPSON-F17S1G2
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 161
