Salta al contenuto principale
Lenovo ThinkPad T431S Screen Replacement
Cosa ti serve
  1. Lenovo ThinkPad T431S Screen Replacement, Screen: passo 1, immagine 1 di 2 Lenovo ThinkPad T431S Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use the Jimmy tool to remove the screen bezel with a gentle prying motion.
  2. Lenovo ThinkPad T431S Screen Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad T431S Screen Replacement: passo 2, immagine 2 di 2
    • Remove the four 3.0 mm screws in the four corners of the screen with a Phillips #1 screwdriver bit.
    • While removing the screws, pry the screen off with an opening tool.
    • If your screen is cracked, use caution, as there will be broken glass or sharp parts.
  3. Lenovo ThinkPad T431S Screen Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad T431S Screen Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad T431S Screen Replacement: passo 3, immagine 3 di 3
    • Lift screen off of top panel to reveal LCD power plug/connector.
    • There will be a wire attaching the screen to the rest of the device.
    • Remove the tape on the wire so you can unplug the connection, pulling upwards.
    • Information about disposal of your damaged screen can be found at E-Waste Recycling
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 13
Tutti i Tempi: 977
