Salta al contenuto principale
Lenovo ThinkPad T431S Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad T431S Battery Replacement, Battery: passo 1, immagine 1 di 2 Lenovo ThinkPad T431S Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remember, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off before starting any disassembly.
    • Use a Phillips #1 screwdriver bit to remove the eight 5mm screws from the back panel.
    • Once the screws are loose, use the three opening tools to loosen and remove the back panel.
  2. Lenovo ThinkPad T431S Battery Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T431S Battery Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T431S Battery Replacement: passo 2, immagine 3 di 3
    • Carefully unplug the battery cable from the connector on the motherboard, using your fingers to pull the cable straight out of the port.
  3. Lenovo ThinkPad T431S Battery Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad T431S Battery Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad T431S Battery Replacement: passo 3, immagine 3 di 3
    • Unscrew the five 4mm screws that are holding the battery secure with a Phillips #1 screwdriver.
    • Remove the Li-polymer battery by lifting it directly out of the device.
    • Information about disposal of your damaged battery can be found at E-Waste Recycling
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,406
