Salta al contenuto principale
Lenovo ThinkPad T430s Hard Drive Replacement
Cosa ti serve
  1. Lenovo ThinkPad T430s Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T430s Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T430s Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Unscrew the 40 mm screw with the Phillips head #1 screwdriver.
  3. Lenovo ThinkPad T430s Hard Drive Replacement: passo 3, immagine 1 di 1
    • Pull the hard drive out with the black ribbon attached to it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 65
Tutti i Tempi: 2,812
