Salta al contenuto principale
Lenovo ThinkPad T14 Gen 3 SSD Replacement
Cosa ti serve
  1. Lenovo ThinkPad T14 Gen 3 SSD Replacement, Back Panel: passo 1, immagine 1 di 2 Lenovo ThinkPad T14 Gen 3 SSD Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use a JIS #1 screwdriver to loosen the seven screws from the back panel.
    • Turn each screw counter-clockwise at least 3 turns and move on to the next step.
    • Screws will not come out of the panel, so you don't have to worry about losing them.
    • Place the end of a spudger or opening tool into the seam to gently separate the back cover from the rest of the device.
    • Slide the opening tool around the perimeter of the device to release the clips that hold the back panel to the device.
    • Remove the back panel.
  2. Lenovo ThinkPad T14 Gen 3 SSD Replacement, Battery: passo 2, immagine 1 di 2 Lenovo ThinkPad T14 Gen 3 SSD Replacement, Battery: passo 2, immagine 2 di 2
    • Use a JIS #1 screwdriver to remove six M2 x 5 mm screws that hold the battery in place.
    • There is a risk to your laptop if the battery is not discharged properly.
  3. Lenovo ThinkPad T14 Gen 3 SSD Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad T14 Gen 3 SSD Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad T14 Gen 3 SSD Replacement: passo 3, immagine 3 di 3
    • Slide the battery from the battery connector and remove it.
  4. Lenovo ThinkPad T14 Gen 3 SSD Replacement, SSD - Hard Drive: passo 4, immagine 1 di 2 Lenovo ThinkPad T14 Gen 3 SSD Replacement, SSD - Hard Drive: passo 4, immagine 2 di 2
    • Use a JIS #1 screwdriver to remove the single screw securing the SSD. As seen circled here opposite of the connector.
    • Put the screw somewhere safe to use for the replacement SSD.
  5. Lenovo ThinkPad T14 Gen 3 SSD Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T14 Gen 3 SSD Replacement: passo 5, immagine 2 di 2
    • Place your fingers on either side of the card near the port, and gently pull it straight out.
    • Be careful not to use too much pressure or bend the card
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 78
Ultimi 30 Giorni: 323
Tutti i Tempi: 1,411
