Salta al contenuto principale
Lenovo ThinkPad Edge E420s Hard Drive Replacement
Cosa ti serve
  1. Lenovo ThinkPad Edge E420s Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Hard Drive Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: passo 3, immagine 3 di 3
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Hard Drive Replacement: passo 4, immagine 1 di 1
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Hard Drive Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: passo 5, immagine 3 di 3
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 44
Tutti i Tempi: 2,875
