Salta al contenuto principale
Lenovo Tab S8 Battery Replacement
Cosa ti serve
  1. Lenovo Tab S8 Battery Replacement, Battery: passo 1, immagine 1 di 2 Lenovo Tab S8 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the device is powered off.
    • Gently insert a spudger into one of the bottom corners between the screen and body case.
    • Slide the spudger along the inside of the crack in order to pry the case open.
    • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
  2. Lenovo Tab S8 Battery Replacement: passo 2, immagine 1 di 3 Lenovo Tab S8 Battery Replacement: passo 2, immagine 2 di 3 Lenovo Tab S8 Battery Replacement: passo 2, immagine 3 di 3
    • After removing the cover, remove the M1.6 x 2 mm screw from the battery cable with the JIS J000 screwdriver.
    • Using screwdriver bits that do not fit in the screw head might strip the screw and render it unusable.
    • Remove the tape by gently scraping the edges up with the spudger.
  3. Lenovo Tab S8 Battery Replacement: passo 3, immagine 1 di 3 Lenovo Tab S8 Battery Replacement: passo 3, immagine 2 di 3 Lenovo Tab S8 Battery Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Before removing the battery, be sure to disconnect the ribbon cables underneath it. The cables might stick to the battery during removal and cause damage.
    • Gently lift the flaps on the four ZIF connectors to disconnect the cables.
    • Use the plastic card to gently pry the battery from the device.
    • There may be glue holding the battery to the device. Use the spudger to detach any glue while the battery is partially raised by the card.
Conclusione
Altre 15 persone hanno completato questa guida.
USF Tampa, Team 3-6, Eyestone Fall 2015 Membro di USF Tampa, Team 3-6, Eyestone Fall 2015
USFT-EYESTONE-F15S3G6
3 Membri
11 Guide realizzate
Un commento
Where we can buy battery
rithwik reddy gorripati - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 70
Tutti i Tempi: 13,726
