Salta al contenuto principale
Lenovo Ideapad 320-17IKB Motherboard Replacement
Cosa ti serve
  1. Lenovo Ideapad 320-17IKB Motherboard Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 2, immagine 1 di 2 Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 3, immagine 1 di 1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 4, immagine 1 di 2 Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 4, immagine 2 di 2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Motherboard Replacement, Battery: passo 5, immagine 1 di 2 Lenovo Ideapad 320-17IKB Motherboard Replacement, Battery: passo 5, immagine 2 di 2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 6, immagine 1 di 2 Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 6, immagine 2 di 2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Motherboard Replacement, Fan: passo 7, immagine 1 di 2 Lenovo Ideapad 320-17IKB Motherboard Replacement, Fan: passo 7, immagine 2 di 2
    • Remove five 7mm Phillips #00 screws from the cooling fan.
  8. Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 8, immagine 1 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 8, immagine 2 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 8, immagine 3 di 3
    • Gently lift the fan assembly out of the laptop.
    • Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
  9. Lenovo Ideapad 320-17IKB Motherboard Replacement, Heat Sink: passo 9, immagine 1 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement, Heat Sink: passo 9, immagine 2 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement, Heat Sink: passo 9, immagine 3 di 3
    • Gently lift and remove the heat sink and set it aside.
  10. Lenovo Ideapad 320-17IKB Motherboard Replacement, Wi-Fi Card: passo 10, immagine 1 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement, Wi-Fi Card: passo 10, immagine 2 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement, Wi-Fi Card: passo 10, immagine 3 di 3
    • Remove the single 3mm Phillips #0 screw from the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the laptop.
  11. Lenovo Ideapad 320-17IKB Motherboard Replacement, Motherboard: passo 11, immagine 1 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement, Motherboard: passo 11, immagine 2 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement, Motherboard: passo 11, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Gently pull the blue ribbon marked with "MB" connectors.
    • Gently remove the other connectors in the picture by pulling them straight out.
    • Blue connectors encased in a black holder may require tweezers to unclasp the connector for removal.
  12. Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 12, immagine 1 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 12, immagine 2 di 3 Lenovo Ideapad 320-17IKB Motherboard Replacement: passo 12, immagine 3 di 3
    • Using a Jimmy, gently pry the motherboard from under the corner screw holder with one hand and pull the motherboard out with the other.
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 93
Tutti i Tempi: 6,249
