Salta al contenuto principale
Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Base Cover: passo 1, immagine 1 di 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: passo 3, immagine 1 di 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: passo 3, immagine 2 di 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: passo 3, immagine 3 di 3
    • Remove the six 3.5 mm screws that secure the fans in place using a Phillips #00 screwdriver.
    • Loosen the seven captive screws using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to unwind the black and gray wires from the clips that are holding them onto the left side fan.
  5. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 5, immagine 2 di 2
    • Lift the black piece of cloth tape that secures the right side fan wires to the circuit board.
  6. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 6, immagine 1 di 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 6, immagine 2 di 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 6, immagine 3 di 3
    • Use tweezers to unplug the wiring connectors that are connected to each fan.
  7. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: passo 7, immagine 2 di 2
    • Gently remove the fans from the laptop.
    • There is thermal paste attaching the ducting of the fans that will require some careful prying.
    • When replacing the fan, reapply a pea sized amount of thermal paste to the fan ducts.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 762
