Introduzione
This guide will show you how to remove and replace the RAM module on your Lenovo IdeaPad Flex 5 1570. The RAM, or Random Access Memory, is responsible for the short term storage of data in your computer. Problems will the RAM will manifest in the use of your computer, rather than its startup like the storage component. If you experience glitches or frequent crashes, this may point to an issue in the RAM and you should consider a replacement. On the other hand, if your computer runs slowly or is constantly held up by compute-intensive programs, you may benefit from the speed boost that a RAM upgrade offers. Regardless of your need, the Lenovo Flex 5 1570 is equipped with a single DDR4 RAM slot, so plan accordingly by acquiring one new RAM stick, rather than two.
Cosa ti serve
Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
Push the two tabs on both sides of the RAM stick apart to release the memory module.
Altre 2 persone hanno completato questa guida.
