Salta al contenuto principale
Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Back Panel: passo 1, immagine 1 di 2 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 2, immagine 1 di 3 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 2, immagine 2 di 3 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 2, immagine 3 di 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 3, immagine 2 di 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Battery: passo 4, immagine 1 di 2 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 5, immagine 1 di 3 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 5, immagine 2 di 3 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 5, immagine 3 di 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Daughterboard: passo 6, immagine 1 di 2 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Daughterboard: passo 6, immagine 2 di 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 7, immagine 2 di 2
    • Using the plastic opening tool, disconnect the CMOS battery from the daughterboard by pushing it out towards the direction of the CMOS battery.
  8. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 8, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the single 5 mm screw.
  9. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 9, immagine 1 di 1
    • Using the iFixit Opening tool, remove the silver piece of tape from the device.
  10. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 10, immagine 1 di 2 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: passo 10, immagine 2 di 2
    • Lift the daughterboard up and out of the device.
  11. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, CMOS Battery: passo 11, immagine 1 di 2 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, CMOS Battery: passo 11, immagine 2 di 2
    • Using a plastic opening tool, pry the CMOS battery up and remove it from the device.
Conclusione
Justin Ogihara
Membro da: 09/18/17
24.491 Reputazione
52 Guide realizzate
EDU Team Membro di EDU Team
Community
7 Membri
493 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 71
Ultimi 30 Giorni: 344
Tutti i Tempi: 3,770
