Salta al contenuto principale
Lenovo IdeaPad Flex 4-1470 RAM Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 4-1470 RAM Replacement, Lower Case: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 RAM Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 RAM Replacement: passo 2, immagine 2 di 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 RAM Replacement, RAM: passo 3, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 RAM Replacement, RAM: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • RAM cards can be damaged from exposure to a static charge through contact with the hand or other body parts. Though the damage of one discharge is not severe, multiple exposures can cause your RAM to fail.
    • When changing the RAM please wear an anti-static wrist strap on your dominant hand and attach the alligator clips to one of the screw holes in the laptop body.
    • Using a metal spudger, pry the RAM cover out of the clips on the motherboard. You will need to go around all sides.
    • Remove the cover.
    • When replacing the cover make sure it is in all of the clips.
  4. Lenovo IdeaPad Flex 4-1470 RAM Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 RAM Replacement: passo 4, immagine 2 di 2
    • To remove the RAM card simply pull the clips on the sides outwards and the RAM will tilt up.
    • Gently pull the RAM out of the motherboard.
    • When inserting a new RAM card, ensure you put it in at an angle just like it came out. Then push it down into the clips.
Conclusione
Altre 10 persone hanno completato questa guida.
USF Tampa, Team S1-G6, Thompson Fall 2017 Membro di USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Membri
10 Guide realizzate
5 Commenti
I am an older lady and I know I couldn;t possibly do that,do you have any advice
diane nodwell - Replica
To Diane: Take your device to Best Buy Geek Squad or to Device Pit Stop. Otherwise, Do you have a skilled nephew / neighbor who can replicate this?
Raul Soria - Replica
Can you please confirm if the DDR4 PC4-21300 RAM is accepted by the Flex4? Thanks!
SIW shows as if there are two memory slots.
Serg Strikov - Replica
Hey there,
Any suggestions on which RAM card to buy to replace this one? I have 2 GB of RAM now that came with the laptop and I obviously want to replace it to try and speed up my Lenovo. Will it damage the laptop if the RAM is “too much” for the pc? Can I find a single RAM card that is more than 8 GB or faster? What GB do you suggest for faster speeds?
Thanks for your help.
Christine Portanova - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 61
Tutti i Tempi: 9,999
