Salta al contenuto principale
Lenovo IdeaPad Flex 4-1470 Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Lower Case: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Battery Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Battery Replacement: passo 2, immagine 2 di 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: passo 3, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Battery Replacement: passo 5, immagine 1 di 1
    • Lift the battery up and out of the laptop.
Conclusione
Altre 9 persone hanno completato questa guida.
USF Tampa, Team S1-G6, Thompson Fall 2017 Membro di USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Membri
10 Guide realizzate
2 Commenti
thank for sharing this! I want to check if it is easy to swap HDD/SSD?
pama - Replica
I'm grateful for the individuals who take time to share their knowledge. I'm 63yrs young with no technical skills. I followed your step by step instructions and was successful in changing my laptop battery. THANK YOU! 👩‍🦳👍
iamelara - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 27
Tutti i Tempi: 13,952
