Salta al contenuto principale
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
Cosa ti serve
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: passo 1, immagine 1 di 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 2, immagine 2 di 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 4, immagine 1 di 1
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 5, immagine 1 di 1
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 6, immagine 1 di 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 6, immagine 2 di 2
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: passo 7, immagine 2 di 2
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
Conclusione
Altre 10 persone hanno completato questa guida.
Ammar Dodin
Membro da: 01/19/17
1.057 Reputazione
6 Guide realizzate
UC Davis, Team 1-3, Rodger Winter 2017 Membro di UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Membri
6 Guide realizzate
3Commenti sulla guida
Clear and easy - thanks!
Beth Pierce - Replica
Easy breezy.
danlord65 - Replica
Very good and to the point
al_stewart - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 52
Tutti i Tempi: 10,074
