Salta al contenuto principale
Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 3, immagine 1 di 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 5, immagine 1 di 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 5, immagine 2 di 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: passo 7, immagine 1 di 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: passo 7, immagine 2 di 2
    • Remove the single 2 mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
  8. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 8, immagine 1 di 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 8, immagine 2 di 2
    • Detach the Wi-Fi card from the motherboard using an iFixit opening tool.
  9. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 9, immagine 1 di 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, disconnect the two wires from the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 872
