Salta al contenuto principale
Lego Dimensions Starter Pack LED Chip Replacement
Cosa ti serve
  1. Lego Dimensions Starter Pack LED Chip Replacement, Top Cover Parts: passo 1, immagine 1 di 2 Lego Dimensions Starter Pack LED Chip Replacement, Top Cover Parts: passo 1, immagine 2 di 2
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack LED Chip Replacement: passo 2, immagine 1 di 1
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack LED Chip Replacement: passo 3, immagine 1 di 1
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack LED Chip Replacement: passo 4, immagine 1 di 1
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack LED Chip Replacement: passo 5, immagine 1 di 1
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack LED Chip Replacement, USB Cable: passo 6, immagine 1 di 1
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
  7. Lego Dimensions Starter Pack LED Chip Replacement, LED Chip: passo 7, immagine 1 di 1
    • Pull the black connector of the ribbon away from the LED chip, keeping the connector parallel to the board.
    • Disconnect the connector on the other LED chip as well, if replacing both LED chips or the motherboard
  8. Lego Dimensions Starter Pack LED Chip Replacement: passo 8, immagine 1 di 1
    • Pull the ribbon away from the black connector of the LED chips.
    • Disconnect the ribbon from the other LED chip as well, if replacing both LED chips or the motherboard.
  9. Lego Dimensions Starter Pack LED Chip Replacement: passo 9, immagine 1 di 1
    • Lift up both LED chips. As you are lifting, pull towards the motherboard to release it from the toy pad cover.
  10. Lego Dimensions Starter Pack LED Chip Replacement: passo 10, immagine 1 di 1
    • Lift up the motherboard, and remove the motherboard and LED chips from the toy pad.
  11. Lego Dimensions Starter Pack LED Chip Replacement: passo 11, immagine 1 di 1
    • Flip the motherboard and LED chips over.
    • Desolder the LED chip from the motherboard.
    • Desolder both LED chips, if replacing both LED chips or the motherboard
    • Separate the LED chip(s) from the motherboard.
    • Refer to this guide for soldering and desoldering tips.
Conclusione
Alyssa Lach
Membro da: 11/06/17
509 Reputazione
4 Guide realizzate
IUPUI, Team S5-G2, Baechle Fall 2017 Membro di IUPUI, Team S5-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G2
2 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,236
