Salta al contenuto principale
Lecia DME Light Source Bulb Replacement
Cosa ti serve
  1. Lecia DME Light Source Bulb  Replacement, Light Source Bulb: passo 1, immagine 1 di 3 Lecia DME Light Source Bulb  Replacement, Light Source Bulb: passo 1, immagine 2 di 3 Lecia DME Light Source Bulb  Replacement, Light Source Bulb: passo 1, immagine 3 di 3
    • Set the Microscope up vertically.
    • Unplug the power cord from the microscope.
    • Do not pull from the wire. Hold it by the plug and pull away from the microscope.
  2. Lecia DME Light Source Bulb  Replacement: passo 2, immagine 1 di 2 Lecia DME Light Source Bulb  Replacement: passo 2, immagine 2 di 2
    • Carefully lay the microscope on its back to expose the bottom.
    • Hold it by the base and the frame in order to not to damage the microscope.
  3. Lecia DME Light Source Bulb  Replacement: passo 3, immagine 1 di 3 Lecia DME Light Source Bulb  Replacement: passo 3, immagine 2 di 3 Lecia DME Light Source Bulb  Replacement: passo 3, immagine 3 di 3
    • Pull the release knob away from the base to open the light hatch.
  4. Lecia DME Light Source Bulb  Replacement: passo 4, immagine 1 di 3 Lecia DME Light Source Bulb  Replacement: passo 4, immagine 2 di 3 Lecia DME Light Source Bulb  Replacement: passo 4, immagine 3 di 3
    • Carefully grab both sides of the light bulb.
    • Gently wiggle the light bulb side to side in order to remove it from the socket.
  5. Lecia DME Light Source Bulb  Replacement: passo 5, immagine 1 di 3 Lecia DME Light Source Bulb  Replacement: passo 5, immagine 2 di 3 Lecia DME Light Source Bulb  Replacement: passo 5, immagine 3 di 3
    • Grab a new 20W 12V halogen bulb to replace the broken one.
    • The place for the bulb information is located on the base of the microscope.
  6. Lecia DME Light Source Bulb  Replacement: passo 6, immagine 1 di 3 Lecia DME Light Source Bulb  Replacement: passo 6, immagine 2 di 3 Lecia DME Light Source Bulb  Replacement: passo 6, immagine 3 di 3
    • Take the new light bulb and firmly grasp the sides of it.
    • Insert the new bulb into the now empty socket.
    • Carefully wiggle it into place. Make sure its all the way in the socket to ensure a good connection.
  7. Lecia DME Light Source Bulb  Replacement: passo 7, immagine 1 di 2 Lecia DME Light Source Bulb  Replacement: passo 7, immagine 2 di 2
    • Close the hatch that covers the light bulb.
    • Push against the base until you hear the click of the pull and release knob setting back into place.
  8. Lecia DME Light Source Bulb  Replacement: passo 8, immagine 1 di 3 Lecia DME Light Source Bulb  Replacement: passo 8, immagine 2 di 3 Lecia DME Light Source Bulb  Replacement: passo 8, immagine 3 di 3
    • Hold the microscope by the base and frame and carefully place it upright.
    • Take the power cord and plug it back into the microscope.
  9. Lecia DME Light Source Bulb  Replacement: passo 9, immagine 1 di 1
    • Turn the red dial on the base of the microscope to test the new light.
Conclusione
After replacing the old light your Leica Microscope should be up and working again.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 845
