Salta al contenuto principale
LeapFrog LeapPad2 Explorer Screen Replacement
Cosa ti serve
  1. LeapFrog LeapPad2 Explorer Screen Replacement, Battery: passo 1, immagine 1 di 2 LeapFrog LeapPad2 Explorer Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
    Chiedi a FixBot
  2. LeapFrog LeapPad2 Explorer Screen Replacement: passo 2, immagine 1 di 3 LeapFrog LeapPad2 Explorer Screen Replacement: passo 2, immagine 2 di 3 LeapFrog LeapPad2 Explorer Screen Replacement: passo 2, immagine 3 di 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
    Chiedi a FixBot
  3. LeapFrog LeapPad2 Explorer Screen Replacement, Back Cover: passo 3, immagine 1 di 2 LeapFrog LeapPad2 Explorer Screen Replacement, Back Cover: passo 3, immagine 2 di 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
    Chiedi a FixBot
  4. LeapFrog LeapPad2 Explorer Screen Replacement: passo 4, immagine 1 di 3 LeapFrog LeapPad2 Explorer Screen Replacement: passo 4, immagine 2 di 3 LeapFrog LeapPad2 Explorer Screen Replacement: passo 4, immagine 3 di 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
    Chiedi a FixBot
  5. LeapFrog LeapPad2 Explorer Screen Replacement, Front Cover: passo 5, immagine 1 di 2 LeapFrog LeapPad2 Explorer Screen Replacement, Front Cover: passo 5, immagine 2 di 2
    • Remove the following screws securing the front cover to the main device:
    • Three 6.0 mm Phillips screws
    • Three 7.0 mm Phillips screws
    • Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
    • The white plastic component holding the speaker must be removed to reach the third 7.0 mm Phillips screw. Refer to Step 2.
    Chiedi a FixBot
  6. LeapFrog LeapPad2 Explorer Screen Replacement: passo 6, immagine 1 di 2 LeapFrog LeapPad2 Explorer Screen Replacement: passo 6, immagine 2 di 2
    • Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned.
    Chiedi a FixBot
  7. LeapFrog LeapPad2 Explorer Screen Replacement: passo 7, immagine 1 di 2 LeapFrog LeapPad2 Explorer Screen Replacement: passo 7, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • When unscrewing the game cartridge screws, you will find a loose black plastic component underneath the game cartridge.
    • Use tweezers to remove the piece.
    • In case the piece falls out unexpectedly, refer to this step to make sure you put this piece back in place during the reassembly of your device.
    Chiedi a FixBot
  8. LeapFrog LeapPad2 Explorer Screen Replacement: passo 8, immagine 1 di 2 LeapFrog LeapPad2 Explorer Screen Replacement: passo 8, immagine 2 di 2
    • Desolder the through hole-components in power plugs on both sides of the device where the batteries were once connected.
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • For proper soldering and desoldering techniques reference Come saldare e dissaldare componenti elettrici.
    • Soldering requires the iron to be at hot temperatures and can cause burns. Wear safety glasses as needed.
    • Be extremely careful with the cables in this step as they could melt, burn, or break.
    Chiedi a FixBot
  9. LeapFrog LeapPad2 Explorer Screen Replacement: passo 9, immagine 1 di 2 LeapFrog LeapPad2 Explorer Screen Replacement: passo 9, immagine 2 di 2
    • Pry the power cables from the device using your fingers or tweezers.
    • Now you should be able to lift up the front cover, leaving you with the motherboard and screen.
    Chiedi a FixBot
  10. LeapFrog LeapPad2 Explorer Screen Replacement, Screen: passo 10, immagine 1 di 3 LeapFrog LeapPad2 Explorer Screen Replacement, Screen: passo 10, immagine 2 di 3 LeapFrog LeapPad2 Explorer Screen Replacement, Screen: passo 10, immagine 3 di 3
    • Lift the screen from the motherboard by pushing the board out from the three metal tabs.
    • Do not be too aggressive when separating the components, as the parts are still connected.
    Chiedi a FixBot
  11. LeapFrog LeapPad2 Explorer Screen Replacement: passo 11, immagine 1 di 1
    • Fold screen away from the motherboard along the yellow ribbon, lay the device's components flat open like a book.
    Chiedi a FixBot
  12. LeapFrog LeapPad2 Explorer Screen Replacement: passo 12, immagine 1 di 1
    • Gently remove the tape covering the yellow ribbon connecting screen to motherboard.
    Chiedi a FixBot
  13. LeapFrog LeapPad2 Explorer Screen Replacement: passo 13, immagine 1 di 1
    • To safely remove yellow ribbon, lift up the retaining flap.
    • Removing or reinserting the cable by brute force could damage it.
    Chiedi a FixBot
  14. LeapFrog LeapPad2 Explorer Screen Replacement: passo 14, immagine 1 di 1
    • Pull the yellow ribbon towards the screen to disconnect the screen from the socket on the motherboard.
    • If the flap is up, as show in the picture, no force should be required to remove the cable.
    Chiedi a FixBot
Conclusione
Altre 11 persone hanno completato questa guida.
Nupur Garg
Membro da: 04/12/14
867 Reputazione
7 guide realizzate
Cal Poly, Team 8-10, Regan Spring 2014 Membro di Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Membri
16 guide realizzate
19Commenti sulla guida
where do you get a new screen from????
Paula Leflar - Rispondi Condividi
We got one on eBay. It was actually a LeapPad (original, not a LeapPad 2 Explorer) that would not boot. I figured the screen would be ok, even if the logic board was bad, and it turned out to be true. Our LeapPad 2 Explorer now works great. Bit of a pain moving the screen assembly from the old model to the new one, but it fits fine and works perfectly.
Jeremiah - Rispondi Condividi
Where do you get a new screen from ??? Please help!
Carmen Nida - Rispondi Condividi
where can I get a screen for the leappad2?
sophia - Rispondi Condividi
No need to desolder positive battery terminals... (on step 8)
They pull straight up just like the negative terminals just a bit tighter..
Easiest way to do this is by using a small diameter screw driver... pass it under the upper metal bend of positive contact and pull straight up..
SiRaDuDe - Rispondi Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 107
Tutti i Tempi: 70,529
