Salta al contenuto principale
LG WM3050CW Electrical Noise Filter Replacement
Cosa ti serve
  1. LG WM3050CW Electrical Noise Filter Replacement, Safety Precautions: passo 1, immagine 1 di 2 LG WM3050CW Electrical Noise Filter Replacement, Safety Precautions: passo 1, immagine 2 di 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Electrical Noise Filter Replacement, Unfasten the top panel: passo 2, immagine 1 di 3 LG WM3050CW Electrical Noise Filter Replacement, Unfasten the top panel: passo 2, immagine 2 di 3 LG WM3050CW Electrical Noise Filter Replacement, Unfasten the top panel: passo 2, immagine 3 di 3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Electrical Noise Filter Replacement, Remove the top panel: passo 3, immagine 1 di 2 LG WM3050CW Electrical Noise Filter Replacement, Remove the top panel: passo 3, immagine 2 di 2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Electrical Noise Filter Replacement: passo 4, immagine 1 di 2 LG WM3050CW Electrical Noise Filter Replacement: passo 4, immagine 2 di 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Electrical Noise Filter Replacement, Disconnect the noise filter: passo 5, immagine 1 di 3 LG WM3050CW Electrical Noise Filter Replacement, Disconnect the noise filter: passo 5, immagine 2 di 3 LG WM3050CW Electrical Noise Filter Replacement, Disconnect the noise filter: passo 5, immagine 3 di 3
    • Disconnect the two spade connectors attached to the noise filter.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG WM3050CW Electrical Noise Filter Replacement, Unfasten the noise filter: passo 6, immagine 1 di 1
    • Use a Phillips driver to remove the 12.5 mm-long screw securing the noise filter.
  7. LG WM3050CW Electrical Noise Filter Replacement, Remove the noise filter: passo 7, immagine 1 di 3 LG WM3050CW Electrical Noise Filter Replacement, Remove the noise filter: passo 7, immagine 2 di 3 LG WM3050CW Electrical Noise Filter Replacement, Remove the noise filter: passo 7, immagine 3 di 3
    • Slide the noise filter towards the front of the device to unclip it from the chassis.
    • Pull the filter downward to completely separate it from the device.
    • Remove the filter.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membro da: 06/30/22
30.695 Reputazione
213 Guide realizzate
iFixit Membro di iFixit
Staff
141 Membri
17.895 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 89
