Introduzione
This guide will show you how to disassemble the LG Vu CU920 and remove its motherboard. You will need to handle several 3.5mm screws and remove small components from the motherboard.
Parti
Nessuna parte richiesta.
Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
  • Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
Aggiungi Commento
Remove the battery by placing your fingernail or an opening tool at the bottom edge of the battery and lift it out.
  • Remove the battery by placing your fingernail or an opening tool at the bottom edge of the battery and lift it out.
Aggiungi Commento
  • Remove the two 3.5mm screws above the battery port with a Philips #00 screwdriver.
Aggiungi Commento
  • Pull out the antenna to reveal a third screw.
  • Remove the 3.5mm screw with Philips #00 screwdriver.
Aggiungi Commento
  • Locate the plastic tab next to the charging port and use a plastic opening tool to gently pop it out.
  • Use the plastic opening tool to pry up the edges of the plastic casing. You should be able to slide it around the edge to dislodge it.
Aggiungi Commento
  • Remove the plastic covering to reveal the motherboard.
Aggiungi Commento
  • Locate these six components on the motherboard. They must be detached before the motherboard can be removed.
Aggiungi Commento
  • Gently lift the ZIF connector (black tab) holding the ribbon cable in place. When it is in the upright position, the cable can be removed from the back side.
Aggiungi Commento
  • Remove the jack attached to the red and blue wires by carefully pulling it upward from the motherboard.
Aggiungi Commento
  • Remove the round jack connected to the black cabel by carefully prying it up from beneath with a spudger or plastic opening tool.
  • This jack snaps on, so there will be more resistance than there was with the previous jack.
Aggiungi Commento
  • The remaining three ribbon cables can be removed by gently lifting them by the ends opposite the cables with a plastic opening tool or spudger until they pop out.
Aggiungi Commento
  • To remove the motherboard, gently pry it up with your finger from the charging port.
  • Be careful not to yank the camera's ribbon cable as you lift the board. Make sure that it is in line with its hole in the motherboard.
  • Once the board has been lifted, remove it by pulling it away from the connected edge.
Aggiungi Commento
Conclusione
Gregory Davis
Membro da: 17/04/2013
48 Reputazione
5 Guide realizzate
Cal Poly, Team 8-57, Johann Spring 2013 Membro di Cal Poly, Team 8-57, Johann Spring 2013
CPSU-JOHANN-S13S8G57
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 348
