Salta al contenuto principale
LG V50 ThinQ Screen Replacement
Cosa ti serve
  1. LG V50 ThinQ Screen Replacement, Screen: passo 1, immagine 1 di 3 LG V50 ThinQ Screen Replacement, Screen: passo 1, immagine 2 di 3 LG V50 ThinQ Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Flip the phone over, making sure that the back of the phone is facing up.
    • With an opening pick, run the tool along the edge of the back cover of the phone and carefully pry it open.
  2. LG V50 ThinQ Screen Replacement: passo 2, immagine 1 di 2 LG V50 ThinQ Screen Replacement: passo 2, immagine 2 di 2
    • With the device facing down, remove all 12 1mm Phillips #000 screws.
    • Keep in mind that the screws must be reused at the end of the guide to put the phone back together.
  3. LG V50 ThinQ Screen Replacement: passo 3, immagine 1 di 3 LG V50 ThinQ Screen Replacement: passo 3, immagine 2 di 3 LG V50 ThinQ Screen Replacement: passo 3, immagine 3 di 3
    • Remove the two brackets covering the internal components.
  4. LG V50 ThinQ Screen Replacement: passo 4, immagine 1 di 2 LG V50 ThinQ Screen Replacement: passo 4, immagine 2 di 2
    • Remove the battery connection from its connector port, located above the battery.
    • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
  5. LG V50 ThinQ Screen Replacement: passo 5, immagine 1 di 1
    • With an opening pick (or a similar tool that isn't sharp), run the tool along the edge between the screen and the base of the phone.
    • After the screen is removed from the device, use a 1mm double-sided adhesive along the edges of the phone.
    • Carefully put the replacement screen into place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 58
Tutti i Tempi: 396
