Salta al contenuto principale
LG Tribute Touchscreen Replacement
Cosa ti serve
  1. LG Tribute Touchscreen Replacement, Battery: passo 1, immagine 1 di 2 LG Tribute Touchscreen Replacement, Battery: passo 1, immagine 2 di 2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Touchscreen Replacement: passo 2, immagine 1 di 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Touchscreen Replacement, Mid-panel: passo 3, immagine 1 di 2 LG Tribute Touchscreen Replacement, Mid-panel: passo 3, immagine 2 di 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Touchscreen Replacement: passo 4, immagine 1 di 2 LG Tribute Touchscreen Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Touchscreen Replacement, Motherboard: passo 5, immagine 1 di 1
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
  6. LG Tribute Touchscreen Replacement, Touchscreen: passo 6, immagine 1 di 3 LG Tribute Touchscreen Replacement, Touchscreen: passo 6, immagine 2 di 3 LG Tribute Touchscreen Replacement, Touchscreen: passo 6, immagine 3 di 3
    • Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
    • When the frame is completely free, remove all of the glue.
    • When removing the glue, be sure the speaker grill and LED light spacer do not dislodge.
Conclusione
Altre 12 persone hanno completato questa guida.
4Commenti sulla guida
thank you for all ypu work at web site
salah dholman - Replica
Can you peel away lens without taking apart ?
mikeknapik1 - Replica
Must I remove the motherboard to replace the front cover with the glass?
Deb Schell - Replica
I messed up the speaker is there a way to replace or fix it
bigestbabybratt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 16,218
