Salta al contenuto principale
LG Stylo 2 Charger Port Replacement
Cosa ti serve
  1. LG Stylo 2 Charger Port Replacement, Battery: passo 1, immagine 1 di 3 LG Stylo 2 Charger Port Replacement, Battery: passo 1, immagine 2 di 3 LG Stylo 2 Charger Port Replacement, Battery: passo 1, immagine 3 di 3
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Charger Port Replacement: passo 2, immagine 1 di 3 LG Stylo 2 Charger Port Replacement: passo 2, immagine 2 di 3 LG Stylo 2 Charger Port Replacement: passo 2, immagine 3 di 3
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Charger Port Replacement, Rear Camera: passo 3, immagine 1 di 3 LG Stylo 2 Charger Port Replacement, Rear Camera: passo 3, immagine 2 di 3 LG Stylo 2 Charger Port Replacement, Rear Camera: passo 3, immagine 3 di 3
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Charger Port Replacement: passo 4, immagine 1 di 3 LG Stylo 2 Charger Port Replacement: passo 4, immagine 2 di 3 LG Stylo 2 Charger Port Replacement: passo 4, immagine 3 di 3
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  5. LG Stylo 2 Charger Port Replacement, Motherboard: passo 5, immagine 1 di 3 LG Stylo 2 Charger Port Replacement, Motherboard: passo 5, immagine 2 di 3 LG Stylo 2 Charger Port Replacement, Motherboard: passo 5, immagine 3 di 3
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
  6. LG Stylo 2 Charger Port Replacement, Charger Port: passo 6, immagine 1 di 3 LG Stylo 2 Charger Port Replacement, Charger Port: passo 6, immagine 2 di 3 LG Stylo 2 Charger Port Replacement, Charger Port: passo 6, immagine 3 di 3
    • Place motherboard on safe surface for Soldering Iron use.
    • Desolder the four connections
    • For more information on how to solder and desolder connections, please visit this guide.
    • Use Iron till the port is able to be removed.
    • Remove the port carefully and place on safe surface.
Conclusione
USF Tampa, Team S11-G1, Cheng Spring 2018 Membro di USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Membri
10 Guide realizzate
2 Commenti
The instructions on desoldering the port should not be followed in this guide, as you can clearly see in the pictures they damaged the motherboard. There are more than 4 connections that need to be desoldered. The four connections shown are only anchor points, and there’s several pads (i believe six, aside from the four anchor points) joined to the port that actually transmit the signal. If you do not desolder these points before removing the port, you WILL damage the motherboard significantly and it will require fairly complicated repair, or the replacement of the motherboard entirely, which is the most expensive component of the phone and holds all of the user information. Awful guide.
Clayton Reeser - Replica
I concur that mother board doesnt look good.. Then soldering the new one in.. The heat heat from that cant be good to an already damaged motherboard.. In my opinion get a phone where you can wireless charge it.. Try avoid using the port.. But anyways but if this does do it i’d just go buy me another decent phone.. It is what it is lol..
matthew02727 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 5,829
