Salta al contenuto principale
LG Phoenix 2 Charge Port Replacement
Cosa ti serve
  1. LG Phoenix 2 Charge Port Replacement, Battery: passo 1, immagine 1 di 3 LG Phoenix 2 Charge Port Replacement, Battery: passo 1, immagine 2 di 3 LG Phoenix 2 Charge Port Replacement, Battery: passo 1, immagine 3 di 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Charge Port Replacement: passo 2, immagine 1 di 3 LG Phoenix 2 Charge Port Replacement: passo 2, immagine 2 di 3 LG Phoenix 2 Charge Port Replacement: passo 2, immagine 3 di 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Charge Port Replacement, Motherboard: passo 3, immagine 1 di 2 LG Phoenix 2 Charge Port Replacement, Motherboard: passo 3, immagine 2 di 2
    • Remove all nine of the 3.0mm screws on the back of the phone using a Phillips #0 screwdriver, including the one attaching the camera lens.
  4. LG Phoenix 2 Charge Port Replacement: passo 4, immagine 1 di 2 LG Phoenix 2 Charge Port Replacement: passo 4, immagine 2 di 2
    • With the plastic opening tool, pry between the screen and the outer chrome edge to remove the bottom shield from the rest of the phone.
  5. LG Phoenix 2 Charge Port Replacement: passo 5, immagine 1 di 3 LG Phoenix 2 Charge Port Replacement: passo 5, immagine 2 di 3 LG Phoenix 2 Charge Port Replacement: passo 5, immagine 3 di 3
    • With a plastic opening tool, disconnect all three ribbon connectors from the motherboard: one for the front camera, one for the rear camera, and one for the screen.
  6. LG Phoenix 2 Charge Port Replacement: passo 6, immagine 1 di 3 LG Phoenix 2 Charge Port Replacement: passo 6, immagine 2 di 3 LG Phoenix 2 Charge Port Replacement: passo 6, immagine 3 di 3
    • Using a plastic opening tool, separate the motherboard from the back frame and remove it from the device.
  7. LG Phoenix 2 Charge Port Replacement, Charge Port: passo 7, immagine 1 di 2 LG Phoenix 2 Charge Port Replacement, Charge Port: passo 7, immagine 2 di 2
  8. LG Phoenix 2 Charge Port Replacement: passo 8, immagine 1 di 3 LG Phoenix 2 Charge Port Replacement: passo 8, immagine 2 di 3 LG Phoenix 2 Charge Port Replacement: passo 8, immagine 3 di 3
    • Desolder the USB port from the motherboard and remove it from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Alex Selsley
Membro da: 11/04/19
325 Reputazione
2 Guide realizzate
IUPUI, Team S1-G1, Harley Fall 2019 Membro di IUPUI, Team S1-G1, Harley Fall 2019
IUPUI-HARLEY-F19S1G1
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 683
