Salta al contenuto principale
LG Optimus F60 Charging Port Replacement
Cosa ti serve
  1. LG Optimus F60 Charging Port Replacement, Battery: passo 1, immagine 1 di 3 LG Optimus F60 Charging Port Replacement, Battery: passo 1, immagine 2 di 3 LG Optimus F60 Charging Port Replacement, Battery: passo 1, immagine 3 di 3
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Charging Port Replacement: passo 2, immagine 1 di 3 LG Optimus F60 Charging Port Replacement: passo 2, immagine 2 di 3 LG Optimus F60 Charging Port Replacement: passo 2, immagine 3 di 3
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Charging Port Replacement, Motherboard: passo 3, immagine 1 di 3 LG Optimus F60 Charging Port Replacement, Motherboard: passo 3, immagine 2 di 3 LG Optimus F60 Charging Port Replacement, Motherboard: passo 3, immagine 3 di 3
    • Use the Phillips #000 Screwdriver to remove the eight 4mm screws.
  4. LG Optimus F60 Charging Port Replacement: passo 4, immagine 1 di 2 LG Optimus F60 Charging Port Replacement: passo 4, immagine 2 di 2
    • Insert the iFixit opening tool in the indentation.
    • Pry the plastic using the opening tool to remove the lower back panel.
    • Remove the lower back panel from the device.
  5. LG Optimus F60 Charging Port Replacement: passo 5, immagine 1 di 3 LG Optimus F60 Charging Port Replacement: passo 5, immagine 2 di 3 LG Optimus F60 Charging Port Replacement: passo 5, immagine 3 di 3
    • Insert the iFixit opening tool starting under the charging port.
    • Continue to pry at the edges until loose enough to remove.
  6. LG Optimus F60 Charging Port Replacement: passo 6, immagine 1 di 3 LG Optimus F60 Charging Port Replacement: passo 6, immagine 2 di 3 LG Optimus F60 Charging Port Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Find the digitizer connector in the lower left hand corner of the device.
    • Use the tweezers to gently lift up and remove the connector.
  7. LG Optimus F60 Charging Port Replacement: passo 7, immagine 1 di 3 LG Optimus F60 Charging Port Replacement: passo 7, immagine 2 di 3 LG Optimus F60 Charging Port Replacement: passo 7, immagine 3 di 3
    • Gently pry the motherboard from the digitizer starting from under the charging port.
    • Remove and replace the motherboard.
  8. LG Optimus F60 Charging Port Replacement, Charging Port: passo 8, immagine 1 di 2 LG Optimus F60 Charging Port Replacement, Charging Port: passo 8, immagine 2 di 2
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team S2-G5, Henning Spring 2019 Membro di IUPUI, Team S2-G5, Henning Spring 2019
IUPUI-HENNING-S19S2G5
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 350
