Salta al contenuto principale
LG K30 Charging Port Replacement
Cosa ti serve
  1. LG K30 Charging Port Replacement, Battery: passo 1, immagine 1 di 2 LG K30 Charging Port Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Charging Port Replacement: passo 2, immagine 1 di 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Charging Port Replacement: passo 3, immagine 1 di 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Charging Port Replacement: passo 4, immagine 1 di 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Charging Port Replacement: passo 5, immagine 1 di 2 LG K30 Charging Port Replacement: passo 5, immagine 2 di 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Charging Port Replacement, Motherboard: passo 6, immagine 1 di 1
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
  7. LG K30 Charging Port Replacement: passo 7, immagine 1 di 2 LG K30 Charging Port Replacement: passo 7, immagine 2 di 2
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
  8. LG K30 Charging Port Replacement, Charging Port: passo 8, immagine 1 di 3 LG K30 Charging Port Replacement, Charging Port: passo 8, immagine 2 di 3 LG K30 Charging Port Replacement, Charging Port: passo 8, immagine 3 di 3
    • For a guide on how to solder and unsolder components; please refer to: How To Solder and Desolder Connections
    • Peel back gold plastic protective film on motherboard to reveal 4 solder points which need to be desoldered with the desoldering wick.
    • Use extreme caution: soldering iron can become extremely hot and cause burns.
  9. LG K30 Charging Port Replacement: passo 9, immagine 1 di 2 LG K30 Charging Port Replacement: passo 9, immagine 2 di 2
    • Flip the motherboard over to the backside and use soldering iron to melt the solder on the charging port terminals; use the desoldering wick to remove the solder.
Conclusione
Un commento
Is the K30 the same inside as the K40?
Daisey Flowerr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,155
