Cosa ti serve
Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
Lift battery up here
Passo 2 Midframe
Attenzione: i passaggi 2-3 provengono da una guida contrassegnata come in corso.
Remove 11 Philips screws.
Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
Attrezzo utilizzato in questo passaggio:Halberd Spudger$2.99
Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
Passo 5 Motherboard Removal
Attenzione: il passaggio 5 proviene da una guida contrassegnata come in corso.
Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
The volume button assembly is held onto the frame with fragile plastic tabs.
Use the tip of a spudger or similar tool to gently pry the plastic tabs upwards and outwards.
