Salta al contenuto principale
LG K20 PLUS Midframe Replacement
Cosa ti serve
  1. LG K20 PLUS Midframe Replacement, Remove the back cover and battery: passo 1, immagine 1 di 2 LG K20 PLUS Midframe Replacement, Remove the back cover and battery: passo 1, immagine 2 di 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Midframe Replacement, Midframe: passo 2, immagine 1 di 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Midframe Replacement: passo 3, immagine 1 di 2 LG K20 PLUS Midframe Replacement: passo 3, immagine 2 di 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
Conclusione
Patrick
Membro da: 05/14/14
6.586 Reputazione
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 73
