Salta al contenuto principale
LG Grace Rear Speaker Replacement
Cosa ti serve
  1. LG Grace Rear Speaker Replacement, Phone Assembly: passo 1, immagine 1 di 1
    • Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
  2. LG Grace Rear Speaker Replacement: passo 2, immagine 1 di 1
    • Pull the battery out of the back of the phone. A small indent is present to allow you to pry it out but you may also just flip the phone over and strike it gently against your palm.
  3. LG Grace Rear Speaker Replacement: passo 3, immagine 1 di 2 LG Grace Rear Speaker Replacement: passo 3, immagine 2 di 2
    • Unscrew all of the screws now visible on the back panel of the phone--11 in total. A #00 Phillips screwdriver works here.
    • The screws are M1.3 and 3 mm long.
  4. LG Grace Rear Speaker Replacement: passo 4, immagine 1 di 2 LG Grace Rear Speaker Replacement: passo 4, immagine 2 di 2
    • Insert the Jimmy into the small gap between the edge of the phone screen and body. Gently pry until it pops loose then remove jimmy and use your hands to slowly pry the body away from the screen
  5. LG Grace Rear Speaker Replacement, Rear Speaker: passo 5, immagine 1 di 2 LG Grace Rear Speaker Replacement, Rear Speaker: passo 5, immagine 2 di 2
    • The speaker is located on the plate you pulled away in initial disassembly, not connected to the mother board.
    • Place Jimmy against the edge of the speaker and gently pry out, there are no solder connections holding it in place.
    • When inserting a new speaker, the orientation matters. It will click into place if it's correct, otherwise it will just fall out of the seating.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 33
