Salta al contenuto principale
LG G8 ThinQ Front Cameras Replacement
Cosa ti serve
  1. LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: passo 1, immagine 1 di 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: passo 1, immagine 2 di 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: passo 1, immagine 3 di 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Front Cameras Replacement, Back Panel: passo 2, immagine 1 di 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: passo 2, immagine 2 di 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: passo 2, immagine 3 di 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Front Cameras Replacement, Midframe: passo 3, immagine 1 di 3 LG G8 ThinQ Front Cameras Replacement, Midframe: passo 3, immagine 2 di 3 LG G8 ThinQ Front Cameras Replacement, Midframe: passo 3, immagine 3 di 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Front Cameras Replacement, Front Cameras: passo 4, immagine 1 di 2 LG G8 ThinQ Front Cameras Replacement, Front Cameras: passo 4, immagine 2 di 2
    • Using an opening tool, carefully disconnect the ribbon cables from both cameras.
  5. LG G8 ThinQ Front Cameras Replacement: passo 5, immagine 1 di 3 LG G8 ThinQ Front Cameras Replacement: passo 5, immagine 2 di 3 LG G8 ThinQ Front Cameras Replacement: passo 5, immagine 3 di 3
    • Using an opening tool, carefully pry up and remove both cameras from the phone casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 554
