Salta al contenuto principale
LG G7 ThinQ Speaker System Replacement
Cosa ti serve
  1. LG G7 ThinQ Speaker System Replacement, SIM Card: passo 1, immagine 1 di 1
    • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
    • After the SIM card tray is ejected, remove the SIM card tray from the phone.
    • Remove the SIM card from the tray.
  2. LG G7 ThinQ Speaker System Replacement, Back Cover: passo 2, immagine 1 di 1
    • Place the phone so the back cover is facing upwards.
    • Insert the opening picks one by one onto each side with equal pressure.
    • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
    • If the picks are too thick to fit in, you can use the Jimmy to start the process.
    • Use the pick with the best leverage to pry the back cover away from the phone.
  3. LG G7 ThinQ Speaker System Replacement, Speaker System: passo 3, immagine 1 di 1
    • This device did not come with a midframe, but if yours does, follow the instructions in the teardown video to remove it.
    • Remove the screws along the perimeter and central area of the phone using a Phillips #000 screwdriver.
  4. LG G7 ThinQ Speaker System Replacement, Remove the speaker system: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use your fingers or tweezers to remove the speaker system.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 926
