Salta al contenuto principale
LG G7 Thin Q Back Cover Replacement
Cosa ti serve
  1. LG G7 Thin Q Back Cover Replacement, SIM Card: passo 1, immagine 1 di 1
    • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
    • After the SIM card tray is ejected, remove the SIM card tray from the phone.
    • Remove the SIM card from the tray.
  2. LG G7 Thin Q Back Cover Replacement, Back Cover: passo 2, immagine 1 di 1
    • Place the phone so the back cover is facing upwards.
    • Insert the opening picks one by one onto each side with equal pressure.
    • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
    • If the picks are too thick to fit in, you can use the Jimmy to start the process.
    • Use the pick with the best leverage to pry the back cover away from the phone.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Where can i get screen and touch to buy and how much does it cost
My country is Ghana
duogo nasif - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 43
Tutti i Tempi: 2,348
