Salta al contenuto principale
Introduzione
Use this guide to remove or replace a broken or worn-out screen assembly including the midframe in the LG G3 (D855).
This guide shows how to replace the whole screen assembly of the LG G3 including the midframe. All components such as the vibration motor, the cameras, and the earpiece speaker need to be transferred to the replacement part during the repair process. In case you want to replace the LCD without the frame you need to follow this guide.
  1. Power off your phone before beginning disassembly. Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. Lift the back cover to release the rest of the plastic clips and remove it. In case you can't lift the back cover completely, slide your fingernail or you prying tool around the midframe to release the remaining clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or you prying tool around the midframe to release the remaining clips.
    • Remove the back cover.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess. Lever the battery up until you can get a good grip.
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
  4. Lift the battery out of its recess and remove it. Lift the battery out of its recess and remove it.
    • Lift the battery out of its recess and remove it.
  5. Remove the four Phillips #00 screws (4 mm length).
    • Remove the four Phillips #00 screws (4 mm length).
  6. Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover. Pry up the plastic panel including the loudspeaker until you can get a good grip.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel including the loudspeaker until you can get a good grip.
  7. Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly. Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly. Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. Remove the eight Phillips #00 screws (4 mm length).
    • Remove the eight Phillips #00 screws (4 mm length).
  9. Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard. Pry up the motherboard cover to open the plastic clamps which hold the cover in its place. The clamps can be a bit restive. In case you're having trouble to open them you can flip the opening pick a bit sideways to make the process easier.
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clamps which hold the cover in its place.
    • The clamps can be a bit restive. In case you're having trouble to open them you can flip the opening pick a bit sideways to make the process easier.
    • Work your way along the right edge of the motherboard cover and use the opening pick to pry it up.
  10. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  11. Get a good grip to the motherboard cover assembly and start to lift the right edge of it. The remaining plastic clamps should open during this process or can be unhinged easily by hand. Remove the motherboard assembly.
    • Get a good grip to the motherboard cover assembly and start to lift the right edge of it.
    • The remaining plastic clamps should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  12. Use a spudger to pry up and disconnect the display flex cable. Use a spudger to pry up and disconnect the display flex cable.
    • Use a spudger to pry up and disconnect the display flex cable.
  13. Use a spudger to pry up and disconnect digitizer flex cable. Use a spudger to pry up and disconnect digitizer flex cable.
    • Use a spudger to pry up and disconnect digitizer flex cable.
  14. Use a spudger to pry up and disconnect the rear camera flex cable. Use a spudger to pry up and disconnect the rear camera flex cable.
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  15. Use a spudger to pry up and disconnect the front camera flex cable. Use a spudger to pry up and disconnect the front camera flex cable.
    • Use a spudger to pry up and disconnect the front camera flex cable.
  16. Avoid to damage the flex cables you disconnected during the motherboard removal procedure. Slide an opening pick under the bottom right corner of the motherboard and start to pry it out of its recess by flipping the opening pick sideways.
    • Avoid to damage the flex cables you disconnected during the motherboard removal procedure.
    • Slide an opening pick under the bottom right corner of the motherboard and start to pry it out of its recess by flipping the opening pick sideways.
  17. Slide the opening under the right edge of the motherboard where the sim card slot is located and pry it up by flipping the opening pick sideways until you can get a good grip to it. Slide the opening under the right edge of the motherboard where the sim card slot is located and pry it up by flipping the opening pick sideways until you can get a good grip to it.
    • Slide the opening under the right edge of the motherboard where the sim card slot is located and pry it up by flipping the opening pick sideways until you can get a good grip to it.
  18. Get a grip to the upper part of the motherboard during the removal procedure to avoid breakage. Carefully remove the motherboard.
    • Get a grip to the upper part of the motherboard during the removal procedure to avoid breakage.
    • Carefully remove the motherboard.
  19. Apply a heated iOpener to the top end of your screen to loosen the adhesive beneath the cameras, the vibration motor and the ear piece speaker.
    • Apply a heated iOpener to the top end of your screen to loosen the adhesive beneath the cameras, the vibration motor and the ear piece speaker.
  20. During the removal of the earpiece speaker take care to remove it together with the foam gasket underneath. Use a pair of tweezers to remove the earpiece speaker.
    • During the removal of the earpiece speaker take care to remove it together with the foam gasket underneath.
    • Use a pair of tweezers to remove the earpiece speaker.
  21. Use a pair of tweezers to remove the front camera. Use a pair of tweezers to remove the front camera.
    • Use a pair of tweezers to remove the front camera.
  22. In case you're having trouble to remove the rear camera or the vibration motor reapply the heated iOpener to loosen the adhesive underneath. Use a pair of tweezers to remove the rear camera from its recess.
    • In case you're having trouble to remove the rear camera or the vibration motor reapply the heated iOpener to loosen the adhesive underneath.
    • Use a pair of tweezers to remove the rear camera from its recess.
  23. Insert one half of a pair of tweezers under the vibration motor and pry it up. Use the tweezers to remove the vibration motor. Use the tweezers to remove the vibration motor.
    • Insert one half of a pair of tweezers under the vibration motor and pry it up.
    • Use the tweezers to remove the vibration motor.
  24. Apply a heated iOpener to the bottom end of your screen to loosen the adhesive beneath the headphone jack and the daughterboard.
    • Apply a heated iOpener to the bottom end of your screen to loosen the adhesive beneath the headphone jack and the daughterboard.
  25. Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers. Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers. Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers.
    • Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers.
  26. Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly. Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly. Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly.
    • Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly.
  27. Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
Conclusione
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
If possible turn on your phone and test your replacement part before reassembling your phone.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Altre 119 persone hanno completato questa guida.
Dominik Schnabelrauch
Membro da: 23/11/2016
44.370 Reputazione
223 Guide realizzate
iFixit Membro di iFixit
Community
105 Membri
9.264 Guide realizzate
Ok so after I did all this my screen is black and so I ordered a second screen and also nothing the phone works great and makes noises also touch responds but nothing on lcd just black can you help me with this also if I take battery out and plug up charger it shows a battery warning on lcd so clearly it works
cabinlife27030 - Replica
Has it sustained any water damage?
Josiah Leas -
Did you get it working i have the same issue? the picture displays with the original screen but not with the new one. i have tried 3 different screens and get the same on all of them. i even tried updating to the latest software but only get a black screen, no picture.
When i have had this on iphones i just so a reset by holding down the buttons and the screen starts to work.
Please someone help
Matt -
Same here! I also findout that lcd still works, if you get some flashlight on screen in a dark room, you will see that only backlight not working when battery plugged. I tried to baking it but it still didn't worked. It's obvious that backlight could properly operate as it works when you take off the battery. I'm looking for solutions, if I find any, will wrote it here.
tufekcisencer -
Did someone find a solution to this? I also replaced my screen and it keeps black solid when I turn it on, even with the touch working properly.
fsnaderfb -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 226
Tutti i Tempi: 242,558
