Salta al contenuto principale
LG G Watch R Motherboard Replacement
Cosa ti serve
  1. LG G Watch R Motherboard Replacement, Back Case: passo 1, immagine 1 di 2 LG G Watch R Motherboard Replacement, Back Case: passo 1, immagine 2 di 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Motherboard Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the back case.
  4. LG G Watch R Motherboard Replacement, Motherboard: passo 4, immagine 1 di 2 LG G Watch R Motherboard Replacement, Motherboard: passo 4, immagine 2 di 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Motherboard Replacement: passo 5, immagine 1 di 2 LG G Watch R Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Motherboard Replacement: passo 6, immagine 1 di 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 1-1, Remmell Fall 2015 Membro di USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Membri
14 Guide realizzate
3Commenti sulla guida
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - Replica
Where do I buy a replacement motherboard from??
Brandon Reznik - Replica
Did you ever find anywhere to order a replacement motherboard?
Robert Dye -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 47
Tutti i Tempi: 3,513
