Introduzione
Use this guide to replace the electrical noise filter in your LG front load washing machine.
This filter protects the washer's circuit boards from power surges and spikes. If your washer doesn't power on, this can be a common culprit.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Cosa ti serve
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Remove the screw(s) securing the top panel brackets to the back panel.
Slide the top panel towards the rear of the device to disconnect its clips.
Disconnect the connectors attached to the noise filter.
Unclip the noise filter from the chassis.
Remove the filter.
Repair didn’t go as planned? Ask our Answers community for help.
