Salta al contenuto principale
LG Front Load Washing Machine Drain Filter Replacement
  1. LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: passo 1, immagine 1 di 2 LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: passo 1, immagine 2 di 2
    • Unclip the filter door from its slot in the chassis and let it rest on the ground.
  2. LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: passo 2, immagine 1 di 3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: passo 2, immagine 2 di 3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: passo 2, immagine 3 di 3
    • Place a bowl next to the device.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  3. LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: passo 3, immagine 1 di 3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: passo 3, immagine 2 di 3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: passo 3, immagine 3 di 3
    • Twist the drain filter counterclockwise until it's fully disconnected from the chassis.
    • Remove the drain filter.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membro da: 06/30/22
30.797 Reputazione
213 Guide realizzate
iFixit Membro di iFixit
Staff
140 Membri
18.074 Guide realizzate
Un commento
I need to replace the clip door it fell off when we moved.
Maria Medina - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 122
Tutti i Tempi: 1,356
