Salta al contenuto principale
LG Front Load Washing Machine Door Latch Replacement
Cosa ti serve
  1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: passo 1, immagine 1 di 2 LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: passo 1, immagine 2 di 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Door Latch Replacement, Open the door: passo 2, immagine 1 di 2 LG Front Load Washing Machine Door Latch Replacement, Open the door: passo 2, immagine 2 di 2
    • Open the front door completely.
  3. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: passo 3, immagine 1 di 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: passo 3, immagine 2 di 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: passo 3, immagine 3 di 3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  4. LG Front Load Washing Machine Door Latch Replacement: passo 4, immagine 1 di 3 LG Front Load Washing Machine Door Latch Replacement: passo 4, immagine 2 di 3 LG Front Load Washing Machine Door Latch Replacement: passo 4, immagine 3 di 3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  5. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: passo 5, immagine 1 di 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: passo 5, immagine 2 di 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: passo 5, immagine 3 di 3
    • Use your fingers to pull the boot off its lip in the front panel.
  6. LG Front Load Washing Machine Door Latch Replacement: passo 6, immagine 1 di 3 LG Front Load Washing Machine Door Latch Replacement: passo 6, immagine 2 di 3 LG Front Load Washing Machine Door Latch Replacement: passo 6, immagine 3 di 3
    • Work your fingers around the boot's perimeter until it's completely separated from the panel.
  7. LG Front Load Washing Machine Door Latch Replacement: passo 7, immagine 1 di 2 LG Front Load Washing Machine Door Latch Replacement: passo 7, immagine 2 di 2
    • Use your hands to fold the boot into the drum.
  8. LG Front Load Washing Machine Door Latch Replacement, Unfasten the door latch: passo 8, immagine 1 di 1
    • Remove the screw(s) securing the door latch.
  9. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: passo 9, immagine 1 di 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: passo 9, immagine 2 di 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: passo 9, immagine 3 di 3
    • Reach between the boot and the chassis to grip the door latch.
    • Pull the door latch out of its slot in the chassis to expose it.
    • Don't try to fully remove the door latch yet. It's still connected to a cable harness.
  10. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: passo 10, immagine 1 di 2 LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: passo 10, immagine 2 di 2
    • Disconnect the cable harness from the door latch.
    • Always grip cables by their connectors and not the wires themselves.
    • Remove the door latch.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membro da: 06/30/22
38.507 Reputazione
261 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.665 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 62
Ultimi 30 Giorni: 263
Tutti i Tempi: 8,612
