Salta al contenuto principale
LG Front Load Washing Machine Control Panel Replacement
Cosa ti serve
  1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: passo 1, immagine 1 di 2 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: passo 1, immagine 2 di 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: passo 2, immagine 1 di 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: passo 2, immagine 2 di 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: passo 2, immagine 3 di 3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: passo 3, immagine 1 di 2 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: passo 3, immagine 2 di 2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Control Panel Replacement: passo 4, immagine 1 di 2 LG Front Load Washing Machine Control Panel Replacement: passo 4, immagine 2 di 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: passo 5, immagine 1 di 2 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: passo 5, immagine 2 di 2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Control Panel Replacement: passo 6, immagine 1 di 3 LG Front Load Washing Machine Control Panel Replacement: passo 6, immagine 2 di 3 LG Front Load Washing Machine Control Panel Replacement: passo 6, immagine 3 di 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: passo 7, immagine 1 di 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: passo 7, immagine 2 di 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: passo 7, immagine 3 di 3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: passo 8, immagine 1 di 2 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: passo 8, immagine 2 di 2
    • Remove the screw(s) securing the control panel.
  9. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: passo 9, immagine 1 di 1
    • Remove the screw(s) securing the detergent dispenser.
  10. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: passo 10, immagine 1 di 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: passo 10, immagine 2 di 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: passo 10, immagine 3 di 3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
  11. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: passo 11, immagine 1 di 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: passo 11, immagine 2 di 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: passo 11, immagine 3 di 3
    • Remove the control panel, making sure to thread any cables through the chassis.
  12. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel board: passo 12, immagine 1 di 1
    • Flip the control panel over.
    • Remove the screw(s) securing the control panel board.
  13. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: passo 13, immagine 1 di 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: passo 13, immagine 2 di 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: passo 13, immagine 3 di 3
    • Pull the control panel board out of its slot and remove it.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Altre 2 persone hanno completato questa guida.
Bill Gilbert
Membro da: 06/30/22
38.507 Reputazione
261 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.649 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 201
Tutti i Tempi: 3,858
