Salta al contenuto principale
LG Cosmos Motherboard Replacement
Cosa ti serve
  1. LG Cosmos Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Apply an upward force to slide the back cover off.
  2. LG Cosmos Motherboard Replacement: passo 2, immagine 1 di 1
    • Use your finger to push down on the top of the battery and pull it out.
  3. LG Cosmos Motherboard Replacement, Rear Case: passo 3, immagine 1 di 1
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
  4. LG Cosmos Motherboard Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to pry the rear case loose.
  5. LG Cosmos Motherboard Replacement: passo 5, immagine 1 di 1
    • Once the rear case is loose, lift it from the rest of the phone.
  6. LG Cosmos Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
  7. LG Cosmos Motherboard Replacement: passo 7, immagine 1 di 1
    • Use the plastic opening tool to pry the motherboard loose.
  8. LG Cosmos Motherboard Replacement: passo 8, immagine 1 di 1
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
  9. LG Cosmos Motherboard Replacement: passo 9, immagine 1 di 1
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
  10. LG Cosmos Motherboard Replacement: passo 10, immagine 1 di 1
    • Use your finger to pull the flex cable out from its connector.
  11. LG Cosmos Motherboard Replacement: passo 11, immagine 1 di 1
    • Pull the motherboard away from the rest of the phone.
Conclusione
Cal Poly, Team 13-63, Johann Spring 2013 Membro di Cal Poly, Team 13-63, Johann Spring 2013
CPSU-JOHANN-S13S13G63
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,897
