Salta al contenuto principale
LG Chocolate 3 Display Connector Replacement
Cosa ti serve
  1. LG Chocolate 3 Display Connector Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the phone over so that the backside is facing up.
  2. LG Chocolate 3 Display Connector Replacement: passo 2, immagine 1 di 1
    • Push the battery cover from the indentation and slide it away from the phone to remove it.
  3. LG Chocolate 3 Display Connector Replacement: passo 3, immagine 1 di 2 LG Chocolate 3 Display Connector Replacement: passo 3, immagine 2 di 2
    • Remove the battery from the phone.
  4. LG Chocolate 3 Display Connector Replacement, Side Keys: passo 4, immagine 1 di 2 LG Chocolate 3 Display Connector Replacement, Side Keys: passo 4, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
  5. LG Chocolate 3 Display Connector Replacement: passo 5, immagine 1 di 3 LG Chocolate 3 Display Connector Replacement: passo 5, immagine 2 di 3 LG Chocolate 3 Display Connector Replacement: passo 5, immagine 3 di 3
    • Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
    • The motherboard should be visible. Do not separate the two covers. They should be held together by a screw at the axis of the phone.
  6. LG Chocolate 3 Display Connector Replacement: passo 6, immagine 1 di 2 LG Chocolate 3 Display Connector Replacement: passo 6, immagine 2 di 2
    • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
  7. LG Chocolate 3 Display Connector Replacement, Display Connector: passo 7, immagine 1 di 2 LG Chocolate 3 Display Connector Replacement, Display Connector: passo 7, immagine 2 di 2
    • Keep in mind that you will need to reinstall the side keys after completing this repair.
    • Skip this step if the screen blue and red display connector is already detached from the motherboard.
    • Insert the pointed end of a spudger between the plastic end of the wire and the motherboard socket, then carefully lift or push the wire to disconnect it.
    • You should see two golden pins protruding from the plastic connector.
    • To reconnect, align the two golden pins with their corresponding socket on the motherboard and gently press down until you hear a click indicating a secure connection.
    • To reassemble your device, follow the Side Keys Installation guide in reverse order.
  8. LG Chocolate 3 Display Connector Replacement: passo 8, immagine 1 di 1
    • Skip this step if the screen display connector is already detached from the motherboard. Using a spudger, insert the pointed end between the plastic end of the wire and the motherboard socket, then carefully lift or push the wire to disconnect it. You should see two golden pins protruding from the plastic connector.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Mitchel
Membro da: 04/18/13
1 Reputazione
1 Guida realizzata
Cal Poly, Team 13-62, Johann Spring 2013 Membro di Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 440
