Salta al contenuto principale
Kyocera Hydro Life Charging Port Replacement
Cosa ti serve
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: passo 1, immagine 1 di 2 Kyocera Hydro Life Charging Port Replacement, Charging Port: passo 1, immagine 2 di 2
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: passo 2, immagine 1 di 3 Kyocera Hydro Life Charging Port Replacement: passo 2, immagine 2 di 3 Kyocera Hydro Life Charging Port Replacement: passo 2, immagine 3 di 3
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: passo 3, immagine 1 di 1
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: passo 4, immagine 1 di 3 Kyocera Hydro Life Charging Port Replacement: passo 4, immagine 2 di 3 Kyocera Hydro Life Charging Port Replacement: passo 4, immagine 3 di 3
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: passo 5, immagine 1 di 3 Kyocera Hydro Life Charging Port Replacement: passo 5, immagine 2 di 3 Kyocera Hydro Life Charging Port Replacement: passo 5, immagine 3 di 3
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: passo 6, immagine 1 di 2 Kyocera Hydro Life Charging Port Replacement: passo 6, immagine 2 di 2
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: passo 7, immagine 1 di 1
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: passo 8, immagine 1 di 1
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: passo 9, immagine 1 di 1
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: passo 10, immagine 1 di 1
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 996
